4 members (sawdust54, G508, Peggy M, Uncles51), 86 guests, and 3 robots.
Topics128,028
Posts1,055,414
Members48,422
1 Offline
The Genius who did shade tree mechanic work on my 1951 one ton for previous owner decided to fill it with chassis Lube Grease. Any suggestions on removing it? Is a total tear down needed? Would John Deere Corn Head grease be acceptable to use or is that bad following worse lube for this application? Thanks in advance, Jerry
Easy enough to take apart to clean and inspect. Corn head grease is the best option for your steering box.
Bruce
My Trucks
Stuff I Collect
I dug out what I could from my box with a large flat blade screw driver then added 90 weight gear oil. Everything mixed up nicely over time and the box functions nicely, with no leaks. I adjusted the steering box as per the Manual and was able to find tight spot at the center just like the book says.
Go like Carl suggests, dog out what you can and add liquid lube to it, it will thin down and make a nice combination.
Joe
