2 members (delky, Steelonsteel), 235 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
8
8 Offline
I have been chasing down an electrical problem in my rewired, rebuilt '48 1.5ton, I am just curious what others ammeter reads parked?
I believe they should be at, or barley below the center mark in the gauge?
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
"about" center, they all vary a bit, they're not precision instruments .... if you question whether you might have a slight "leak", take a wire off the gauge and see where it sits, should be the same as with key off
V
V Offline
Mine sits a hair to the discharge side, even w/the battery disconnected.
As stated, best way to tell if it's just the gauge or if it is a discharge is to remove power from the vehicle and see where it sits.
Good luck
Dave
8
8 Offline
Thanks Bill and Dave! That is what I thought, but wanted to confirm.
Curt Warren
Salt Lake City
