1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I have a 46 chevy with a 6V system. I just finished the wiring. Well except for some wrapping and clean up. I added turn signals. Note: I ran the turn signal wires inside the column and protected them with a PVC pipe from the actual steering shaft. I replaced the front parking light lamp socket and the 4 rear lamp sockets with two lamp sockets. I used an 1157 lamp socket and 1154 dual fulfillment 6V lamps. I replaced the 6V head lights with 6V halogen lamps. The 1154 lamps are some where between 6 to 10 times brighter. The halogen head lights I don't see allot of difference. I have photos in my photo bucket if you want to see what they look like. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | You could add a relay switch for more power to your new halogen lamps. Hopefully, your generator will provide your battery with enough electricity to keep it fresh.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Confused. How would a relay change the power. I rewired my truck all with 14 awg except for the main power conductors they are all 10 awg. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Using a relay might make your lamps brighter by doing two things. 1. The current to your lights must run thru your light switch and all the wire from the source to the lamps as it is now wired. All that adds resistance thus reducing the current to the lamps. 2. Using the relay and using larger wires connected close to the power source allows for even more current to reach the lights. An added plus is less stress(load)on the light switch means longer life.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | 14 gauge wire is more than sufficient, It will handle 15-20 amps. Your wiring is sound enough to make the most picky electician jealous.
As far as the relay goes, If you have a good light switch with clean contacts, I don't really see any advantage. Typically, you would only use them for a high demand load.
One option, would be to run an 8 volt battery, that would guarantee everything to be brighter.
