6 members (53again, Cosmo, Hotrod Lincoln, mason86, Gray_Ghost, Jon G), 98 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#99819 03/13/2007 2:17 PM
I am converting my 1950 3600 to 12-volts and was wondering if anyone had a part number for a readily available voltage regulator? Also any tricks or suggestions on the conversion would be appreciated. I bought the book from Jim Carter which has good info but every little nugget helps.
#99820 03/13/2007 2:39 PM
Brad Allen,
Are you going to install a 12 volt generator, or a old style alternator?
Stuart
#99821 03/13/2007 8:50 PM
I am going to use the old style alternator and have the coils swapped out for 12-volts.
#99822 03/13/2007 8:51 PM
Sorry I meant to say 6-volt generator with new 12-volt field coils.
#99823 03/13/2007 10:09 PM
Brad Allen,
It sounds like you are going for the stock appearance. My book shows a Delco regulator #1118517. This is a 12 volt, negative ground regulator that's adjusted to a max output of 55 amps. I searched the web and came up empty, so I don't know if the number is still good.
Wouldn't some of the specialty suppliers have a 12 volt regulator for just this swap. Have you checked the 'Links' section.
Stuart
#99824 03/14/2007 5:44 PM
you lost me. alternators would be 12V? I picked up a 12 volt regulator for a chevy generator from NAPA.
"It ain't a truck if you can't hose out the cab."
#99825 03/16/2007 6:28 PM
I would like to keep the original generator and switch the coils internally to 12-volt Chester. I didn't want to modify brackets, pulleys, etc. I was wondering if anybody had an actual part number like the one Stuart provided for the Delco. I have several of the catalogs for general parts suppliers and saw lots of 6-volt but no 12-volt regulators in the resources I have.
#99826 03/17/2007 7:08 PM
Well according to the NAPA parts book the regulator you would need for the 12v conv would be a NAPA part number VR122 with a 30/35 amp gen. with the optional 50 amp gen you would need a VR136 regulator...... This is according to NAPA book #103 sept. 1982 ign&electrical sys parts "early Model cars&trucks"
Now if I change to the Standard Blue-Streak book (IG-68)
I get the following info;
53-62 25/30/35 amp. (except gen #'s 1102055,176,177,1105127)
will use a VR-20 regulator
Gen # 1102055,176,177 will use a VR-22 regulator
Gen # 1105127 will use a VR-30 regulator
The 50 amp Generator will use a VR-18 regulator
if needed for anyone I can also provide the corrisponding bushing/brush set ##'s for the early gen's
I hope this helps you and others
Michael
\'48 chev 2-ton boom truck (Boomer)
'49 Chev 2-ton flat bed
'65 Chev 35ft school bus
'88 GMC 6500
'72 Superior 26ft class "A" coach
'50 Farmall "M"
'71 MGB GT
'68 Austin-Healey Sprite
'65 Austin-Healey Sprite
and various other odd British cars
and lots of old radios.....
Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
#99827 04/11/2007 1:18 AM
Junior Member
Junior Member
you are welcome to have my regulator off of my 1960 c10, I just switched out to a 1 wire GM alternator with internal regulator, I'd be happy to send it to you
cw
#99828 04/17/2007 8:07 PM
I picked up a 60 something chevy 12V Generator at a swap meet. Looks just like the 6V on my 53. The 53 came with a 6 volt generator with a 12 volt regulator. I used the generator on the 39, so don't know how well it worked for the PO.
#99829 04/17/2007 8:27 PM
Thanks Apache, let me know what the price to ship it would be and your address and I'll send you a MO upfront for the costs. A most generous offer to by the way, I'll tell you I just love this forum!
