8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible), 58 guests, and 1 robot.
Topics128,049
Posts1,055,699
#998047 01/09/2014 7:32 AM
Hey guys I'm kinda bummed out here because I bought this 57 3100 thinkin it had the original engine in it and it turns out to be I searched my engine casting number and it's a 1957 235 out of a passenger vehicle. How can I find out if the head matches the engine or maybe get a clearer idea whether or not it's a Franken-engine? Does this mean I have hydrolic lifters? My block is 3837004, engine stamped F7I5H (the "I" I am unclear whether it is a 1 or an I), the number stamped on the heads is B38 848 850 ( the 850 is directly under the 848), and also CON4 G107. Any help would be much appreciated guys. Thank you!
F715H ( here is code information)
Flint, Mi
7 = July
15 = 15th
H = 3100-3800 235 (A, AD, or B would indicate a car engine)
Where did you get the ID information on your engine?
G107
G = July
10 = 10th
7 = 1957
Here are locations of most of the useful codes on the head and block.
Post both the head and block date casting codes. They should be dates that are fairly close in time to each other.
He's is stamped 3836848
I should have been clearer.
Where did you get information that your engine is 1957 235 out of a passenger vehicle?
38336848 is a head casting code that was used on all 1956 and later 235 heads - cars & trucks.
There is a topic on this forum where someone posted a guide to figuring out engine codes. I believe it's the very first topic under the engine forum.
