0 members (),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2013 Posts: 73 | What is a good caulk or sealer to re-do the rain trough on the top of my 61 cab? a lot of the old is gone or loose and I want to re-do it either before or after painting the cab depending on which works best. Raymond | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I would just get the paintable automobody caulking from any bodyshop supply store. It works good. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | I think all of us have seen the cracked/missing seam sealer in drip rails. The lesson to take from this is to strip the drip rails clean, epoxy prime, then reseal. In the event of a future occurrence you will have protection under the sealer.. | | |
