0 members (),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99765 03/10/2007 11:46 PM | Joined: Dec 2006 Posts: 27 Apprentice | | Apprentice Joined: Dec 2006 Posts: 27 | Hi all,
Recently reassembled my foot activated starter & I seem to be missing somthing. When turned on end the starter shaft protrudes through the front houseing causing the armature to fall away from the brushes. I am wondering if there is a clip that should be installed on the shaft in front of the drive assy. but before the front bushing. There is a groove in the shaft but I dont recall a clip there on dissassembly. Any suggestions? Thanks. | | |
#99766 03/11/2007 1:32 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Metricnut,
Yes, a snap ring goes there. The parts breakdown of the starter actually shows two rings..one where you indicate, and another on the back, or starter side of the drive gear. Do you see a snap ring groove there as well?
They call these snap rings, but as I recall, they are circular rings, but not flat, and they don't have little ears like today's style does.
I don't think a conventional 'snap ring' will work. These are specific for this kind of application.
This ring sometimes ends up buried in a small recess in the end of the starter drive gear.
Stuart | | |
#99767 03/11/2007 1:32 AM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | yup , i believe there is a c-clip or a retainer on the shaft at the end where the shaft goes thru the nose cone. | | |
#99768 03/11/2007 1:34 AM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | is'nt it a c-clip with a concave washer that goes over the top , to hold it ? | | |
#99769 03/11/2007 2:09 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Metricnut, I might have steered you wrong. There is no snap ring on the back of the drive gear. The item I saw on the front isn't called a snap ring, but is called a spacer. I am really reaching on this, but isn't the shaft turned down on the front, and the snout, or drive housing along with the spacer mechanically hold the armature in the starter. In the enclosed link, you can see the reduced shaft diameter on the end that goes through the bushing. This is what holds the armature in the starter..isn't it! I know exactly what ring and concave washer Project 39 is talking about. The starters I have at work for the Perkins diesels have this setup. This is the picture I was looking at. http://chevy.tocmp.com/1948_51truckshop/51ctsm1221.htm Stuart | | |
#99770 03/11/2007 2:59 AM | Joined: Dec 2006 Posts: 27 Apprentice | | Apprentice Joined: Dec 2006 Posts: 27 | Thanks. The washer in question is in place. There is a copper bushing inside the nosecone as well. Should this copper bushing have a cap on it to keep the starter shaft from poking through the houseing? | | |
#99771 03/11/2007 4:09 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Metricnut,
I thought the end of the shaft had a reduced diameter that fit snugly in the brass bushing. This 'step' is what captures the armature and doesn't allow it to move forward. The washer keeps the drive gear from rubbing on the cast housing as the starter spins. Does your shaft have this step, and is it snug in the bushing?
Stuart | | |
#99772 03/11/2007 2:56 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | there is a round retaining clip with a ring that clips over it on the shaft groove...doc | | |
#99773 03/11/2007 3:51 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | This comes in a 3 piece set. There is a spacer with a recess that goes on first. Then the snap ring goes on & is popped into the recess. Then the thrust washer goes on with the shoulder faceing the snap ring. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
