1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#997456 01/07/2014 3:53 AM
I stumbled across this and though I'd share. A place called Coleman's Surplus has a stock of Chevy rear axles for sale. link
regards,
Leon
Leon #997492 01/07/2014 6:39 AM
Nice! very tempting. Thanks for the link.
Leon #997551 01/07/2014 4:33 PM
My guess is that they probably aren't NOS, just salvaged from military trucks. You can bid online for them. The 1 ton axles are more than likely 4.56 and the 10 bolt axles are 3.08 gears.
http://www.govliquidation.com/auction/view?auctionId=7090590&convertTo=USD
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Leon #997711 01/08/2014 2:26 AM
For some reason there are many spares floating around for the CUCV Chevy Blazer. I would not be surprised that they are true NOS parts. The Blazer CUCV always had a gear ratio of 3.08, and the 1.25 ton pick-up version CUCV had a gear ratio of 4.56.
Lots more pictures
Leon #1000452 01/19/2014 10:19 PM
I called this outfit awhile back asking about the 10 bolt posi rear axle assembly, the lady I spoke to said I need to talk to the boss who was not there and does not return phone calls.
This axle assy is the perfect setup if you plan on installing a 3speed od trans in your AD.
Good Luck on getting info from these folks.
Rustnut
There is not a tool made that if you don't try hard enough you can't break!
1952 3100 261 T5 3.08 Gov Locker
Rustnut #1000471 01/19/2014 11:38 PM
ODSS President
ODSS President
Rustnut
NOT good for an od, 3.08 X .70 = 2.156. Regular 3 or 4 speed yes, but not a good rear for an overdrive.
~ Cosmo
1949 Chevy Half Ton
Leon #1000488 01/20/2014 1:08 AM
I have to agree with Cosmo but add they would be great for a 3 or 4 speed automatic too. I have a '59 GMC 3.07 under my '56 with a TH400.
