0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I stumbled across this and though I'd share. A place called Coleman's Surplus has a stock of Chevy rear axles for sale. link regards, Leon | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | Nice! very tempting. Thanks for the link. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | For some reason there are many spares floating around for the CUCV Chevy Blazer. I would not be surprised that they are true NOS parts. The Blazer CUCV always had a gear ratio of 3.08, and the 1.25 ton pick-up version CUCV had a gear ratio of 4.56. | | | | | Joined: Apr 2012 Posts: 44 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 44 | I called this outfit awhile back asking about the 10 bolt posi rear axle assembly, the lady I spoke to said I need to talk to the boss who was not there and does not return phone calls. This axle assy is the perfect setup if you plan on installing a 3speed od trans in your AD. Good Luck on getting info from these folks. Rustnut
There is not a tool made that if you don't try hard enough you can't break! 1952 3100 261 T5 3.08 Gov Locker
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | I called this outfit awhile back asking about the 10 bolt posi rear axle assembly, the lady I spoke to said I need to talk to the boss who was not there and does not return phone calls. This axle assy is the perfect setup if you plan on installing a 3speed od trans in your AD. Good Luck on getting info from these folks. Rustnut NOT good for an od, 3.08 X .70 = 2.156. Regular 3 or 4 speed yes, but not a good rear for an overdrive.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have to agree with Cosmo but add they would be great for a 3 or 4 speed automatic too. I have a '59 GMC 3.07 under my '56 with a TH400. | | |
