Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (carbking, baldeagle, NJC), 35 guests, and 2 robots.
Topics128,005
Posts1,055,254
Members48,418
#982006 10/28/2013 5:15 PM
Hi. I will begin work on a 1933 REO speedwagon. The truck has a 230 from a 1962 Nova. Is this the same 230 you folks have in your 1/2 tons? How do I ID the engine, bell housing, and transmission? Are numbers stamped on them and where?
Dennis
Dennis
oldbluetruck #982049 10/28/2013 8:19 PM
My 1965 230ci has a stamped number just to the rear of the distributor hole. I'll let others say what they know about the tranny and bell ID.
oldbluetruck #982052 10/28/2013 8:39 PM
If it's from a 62 model, it's probably a 194, not a 230. All of the second-generation 6 cylinder engines have the same bellhousing bolt pattern as the V8's. Any manual transmission from the mid-1950's on could be bolted onto the bellhousings that fit those engines, 3, 4, or 5 speeds. That would include the Muncie 3 and 4 speeds, the Saginaw 3 and 4 speeds, and various Borg-Warner 3,4, and 5 speeds with the Chevrolet bolt pattern. Even an SM-420 could bolt up and work.
oldbluetruck #982063 10/28/2013 9:28 PM
Thank you.
I believe the engines stamped number is P1024PV
Dennis
oldbluetruck #982710 10/31/2013 3:35 AM
Found out the ending PV shows it to be a 64-66 230 with a 3 speed manual transmission. I used Nova Resourses website
Dennis
oldbluetruck #997228 01/06/2014 9:53 AM
The six cylinder in the trucks were a 230 CID in '65 & a 250 CID in '66.
oldbluetruck #1001701 01/24/2014 10:48 PM
Riding in the Passing Lane
If it did come out of a Nova It has or did have the oil pan sump in the front part of the pan & the dipstick in front also.
1972 Chevy c10 Cheyenne Super
