6 members (Otto Skorzeny, klhansen, sron48, Hotrod Lincoln, Shade Baby, Phak1), 86 guests, and 4 robots.
Topics128,041
Posts1,055,483
Members48,424
#99709 03/07/2007 3:01 PM
i want to upgrade the 39 from 6v. to 12 volt . it's a 235 , but what size diameter pulley should go on the new alternator ( to keep it charging well ) ?
#99710 03/07/2007 7:56 PM
project 39,
If you buy a rebuilt or new alternator from your auto parts store, it will have the proper diameter pulley on it for its intended application. The same would hold true for a salvage yard..the alternator will have the pulley on it that makes it work right.
The RPM range of your 235 won't be far enough out from alternator equipped engines for you to need to change pulleys. It will probably charge fine. The single wire alternators require an initial 'rev' to get them going, but this would be done almost automatically and is the nature of this style.
Your '39 probably has a big old belt on it and this might be the issue. I am winging most of this post, so the best thing for you to do is go to the 'search' icon in the upper right of this page and look for 'alternator pulley' or 'generator pulley' and read the true poop!
Stuart
#99711 03/07/2007 10:26 PM
thanks for the input stuart !
#99712 03/07/2007 11:25 PM
Riding in the Passing Lane
Stuart is right. If you have the wide belt a pulley off the gen. will fit. The alt doesn,t have a groove & key. If you tighten the nut good it will stay.
1972 Chevy c10 Cheyenne Super
