| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99706 03/07/2007 4:28 AM | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | a little help please. I'm stumped. I have removed gas tank sender unit to replace gasket so I though I should check unit. hooked up guage to positive on battery..hooked top of sending unit to other side of guage and ground wire to negative on battery. Gas guage reads about 1/4. when I raise float lever up which should read full it actually reads less than 1/4 on guage. any thoughts??? | | |
#99707 03/07/2007 4:44 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | evac34, You say that you hooked the gauge to the positive of the battery...does this mean the gauge is out of the truck? The case of the gauge needs to be grounded too. Your wiring should be; power to fuel gauge. Wire from gauge to sender. Body of sender AND case of fuel gauge hooked to ground. Try that, but don't blow yourself up! The electrical forum would be a great place for your next 'juice' question. Stuart | | |
#99708 04/11/2007 1:21 AM | Joined: Feb 2007 Posts: 6 Junior Member | | Junior Member Joined: Feb 2007 Posts: 6 | careful, I had problems with my gauge and found that the the connection from the float to the "sending unit" was cracked, ended up picking up a new one from ecklers for $50, if your having problems do yourself a favor and replace the sending unit
cw
