| | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 36 New Guy | | New Guy Joined: Oct 2013 Posts: 36 | Happy New Year everyone!! I picked up a 1946 216 that I'm going to rebuild and put in my 41 pickup. The engine had been sitting in a friends barn for years. He bought it for a spare but never needed it. It's missing the Rockers and side cover plate. Would I be able to use those parts from my 1940 engine that was in my truck? His oil pan was bad from sitting on the barn floor so I was hopping to swap mine over too the 46 also.
I've taken the engine down to the block and checked mains and Rod bearings. They are all between .0015 and .002 using plastigage. I've honed the cylinders and they look good and measure standard. I've pulled the cam and it looks good also. I don't believe it has many miles on it. My question, is there any tricks, special procedures or things I need to look for as I put this engine back together? I've worked on the Ford 4 bangers but this is my first Chevy Rebuild. Thanks Tom | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | How do you propose to get the cylinders clean after the hone job? Unless it is scrubbed with a stiff-bristle brush and HOT (virtually boiling) water and lots of strong detergent, then rinsed repeatedly with HOT water, there will be enough honing grit left in the cylinders to wear the rings out in a matter of a few hundred miles. I wore out a set of rings on a 2500-mile trip from California to Tennessee after an in the frame rebuild, and I had cleaned the cylinders with lacquer thinner and terrycloth toweling until no dirt showed at all on the rags. Still not clean enough! Jerry
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I've rebuilt all sorts of engines and never had a problem with honing effecting ring wear. Also never had rings not seat in.
I wipe the honing oil out, wipe the walls down naphtha or what ever is handy. Slobber oil on the rings and pistons so they slide through the ring compressor like butter and button it up.
I also use STP for assembly lube on everything that turns, slides or moves except the rings. Crank it with the plugs out until the oil pressure is up and start it up.
