| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | Guys, I have a '52 1/2 ton with the SM420 4-speed and torque tube. While in the process of swapping the 3:90 rearend gears out with 3:55 gears I found out the tranny U-joint and yoke are trashed. I can't seem to find one online anywhere for the 4-speed. Does anyone have any ideas where I might be able to find a yoke? Thx in advance for any help.
1952 Chevy 3100 Semper Fi !
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Try calling Chevs of the 40s and Jim Carter.
I see you have responded to a lot of Parts for Sale listings. Post a Part Wanted ad in the Swap Meet.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Are you referring to the rear yoke? If so that fits 1940-54 pass and 1/2 ton.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I traded one (NOS) to Jim Carter last Sept for my SM420. | | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | Another Stovebolt buddy told me the same thing last night (which I did). I don't know why I didn't think of that. I've looked at both of the websites you mentioned and they don't show the u-joint assembly (with the yoke) for the 4-speed. I believe the splines must be different. I did find Kantor Auto Products in Jersey that shows they have them ($210)and did get a reply from a Stovebolter in CA about a used one ($50). Trying to confirm what the used one is out of before deciding. Thx very much for the reply.
| | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | Dave, What I'm referring to is the yoke where the u-joint sits in one end and the other connects onto the torque tube at the transmission end. Tried copying a link to a pic of what it is. We'll see if that works. [img:left] http://www.kanter.com///images/products/Kanter/thumbnails/universal_joints.jpg[/img]
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I took the U joint out of a 3/4 ton with a 4 speed, had a machine shop machine out the rear part of it and also the rear part out of a 3 spd U-joint. They then welded the output spline in the 3/4 ton joint. Heavier joint than the 1/2 ton set up. Draw back..... No way to separate the u-joint a part like the 1/2 ton joint, so you need to pull the rear end back to remove the torque tube from the rear of the transmission....
John | | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | That gives me an option if I can't find the yoke. Thanks for the info.
