7 members (mick53, elhippie64, papas52, stlcardinalsguy, KEVINSKI, Leo, 1 invisible),
63
Mod | | | Forums66 Topics128,180 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I am adding a cigarette (accessory socket) to my '52. I would like to wire as would have been done originally. Anyone know for sure or can point me some literature/wiring diagram?
Thanks. | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Original-equipment connection point would have been at the back of the ammeter, on the same terminal post as the supply wire for the ignition switch and the Bat. lead from the voltage regulator. Be aware that the connection will be unfused, and shorted cigarette lighter wiring has been the cause of a LOT of under-dash fires. Even if it's not purist stock, I'd recommend a 30 amp inline fuse in that wire. To make it look a little more original, use the round black holder for a glass-tube fuse. Jerry
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 |
Ed
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have done my cigarette lighter as Jerry described, connecting the element lead to a post on the ammeter or the ignition switch; however, the accessories installation instructions connect to a leads on the light switch (lighter and light). | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | figure 135 for truck http://chevy.oldcarmanualproject.com/accessories/1951am/51aim57.htmfactory assembly manual ...pic... I ordered and used the Airtex plug Harold46 linked above. this is after I fried the lighter trying to wire with a standatd terminal. I wired to the ignition terminal with a fuse as suggested. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Thanks everyone. I thought the light switch was probably the right answer and now confirmed. In this instance, the switch is simply used as a terminal block and no added load is put on the switch, so I am ok in wiring it up this way for always "on" power at the lighter socket. | | |
