1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Hi guys. I want to build an engine to learn from and the 261 the goal. I have a great running 235 so I'm in no hurry and can take my time. I know I need head, block, cam, and master rebuild kit. I live in AZ and patricks is nearby so that will help a bunch I imagine. I wondered though what I can take from my 235 and use on the 261 as I have tons of newer parts. Will the radiator, fentons, dual carb and intake, dual exshaust, hei from Langdons, flywheel, starter, etc be able to be reused in the 261? If so that'll shave some cost overall so I thought I'd ask. Also the stomp starter. Did the 261 have a stomp? Or will I need to fabricate something? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Yes, The only real difference is the block, and the head has cooling holes drilled between the cylinders. Many 235 heads have been drilled for use on 261's. Patrick will set you up with what you need. You are near Ptaricks, go talk to him.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Ill be asking them plenty I haven't any doubt! And thanks for the info. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | The 848 casting number late 235 head gives the 261 a good compression bump, and there's a tech tip here on how to drill the steam holes correctly. They're angled slightly to intersect the coolant passages, not absolutely necessary, but it's a very good idea to do it the way the factory did. The main difference in the 261 is the bore size, 3 3/4 inches, which is way more than a 235 block will tolerate. 235 and 261 crankshafts are a direct swap- - -no difference in dimensions or stroke. Some 261's had heavier connecting rods, IIRC. The 261 camshaft is the same grind as the stovebolt-engine early Corvettes used, but there are much more radical cam profiles available aftermarket if you want a hot rod. Jerry
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I'm certainly no engine expert, but my 261 has an 848 head on it. I have a 235 flywheel, stomp starter, same rad and starter motor, also 235 one barrel carb. | | |
