| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | My speedometer worked prior to the engine rebuild but then afterwards it stopped working, and then only sometimes the needle will move but only about half the actual speed.
If* the speedo cable is attached properly, would this most likely be a break inside the speedo gauge or the cable? | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Does the odometer seem correct?
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | What do you mean? When the needle does move, no it is not accurate, its as if its trying to work, then after a few seconds it falls back to 0. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The odometer is the mile counter at the bottom. Does that work OK? | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | There is a cup and a magnet in there. A spring to return the pointer to 0. The cable spins the cup. Magnetic coupling provides the torque to act against the spring. The faster the cup spins the more torque is available to move the pointer. So the way to check it is, pull the cable from the back of the speedo head. Pull the inner cable out and see if it is damaged. The ends are squared off to engage the drive at the trans and the cup. Are they good? is the inner cable nice and smooth? If yes to both then lube it with some light grease and replace in to the outer housing. Slide it all the way back and twist it with your fingers until you feel it engage the drive gear in the trans. Push it in to fully engage. There should be enough sticking out to engage the speedo drive. That drive is the back of the cup. There is a way to lubricate the head but a little WD40 will work, squirt a bit into the place the cable goes to and reattach the cable. Drive it a see what happens. You might need to pull the head out but at least you will know that the cable is OK. If you put the inner cable in and when it engages you can still turn it the problem is the drive gear at the trans. Now you can start at the right end to fix it I hope. Enjoy.
Steve H
