11 members (GMCJammer51, Steveoreno, 4tttt8, Jay R, Joe H, dt235sd, Peggy M, 55shaker, FAST55, 1955 1 Series, Waveski),
95
Mod | | | Forums66 Topics128,180 Posts1,057,164 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 7 New Guy | | New Guy Joined: Oct 2012 Posts: 7 | Fellow StoveBolt members. I am restoring a 1941 Chevy truck model AK ( 1/2 ton). This truck was purchased fully taken apart and all in parts.( Canadian Made ) The box that came with the truck has 79 1/2 + inch long sides with a 49 1/2 inch wide tail gate. The pipe on the top is about 1 3/4 inch diameter on the sides, end plate and tail gate. I purchased what I was told is an "old original" box from a donor truck but once home measured 78 1/4 long sides and tail gate measures 58 inches wide. Tailgate seemed to not match the rest of the box parts? The pipe size measures 1 1/8 inch diameter on sides, front plate and tailgate. The stake sides supports are smaller than my original ones. Both boxes are about 22 ++ inches high Can anyone help me understand what I have received with the original truck and what I have purchased? If anyone has the actual box lengths/widths and top pipe diameter that my truck box should be I would greatly appreciate the info. [email protected]Thanks in advance Murray | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I hope page 22 in this link helps a little bit? GM Heritage Center 1941If the tailgate you got is 58 inches wide that's not off a GM half-ton or 3/4 ton of this era. I can measure my top pipe diameter and box width when I get home. I can't give you a reliable measurement on box side length though, someone else will have to chime in with that. If your sides are 79.5" long, they sound about right to give you that 78" inside length shown in the manual I linked to. Can you post photos of what you have? That might also help. | | | | | Joined: Oct 2012 Posts: 7 New Guy | | New Guy Joined: Oct 2012 Posts: 7 | 46gmcpu Thanks for your reply. I would appreciate knowing your top pipe diameter if possible. I will post some pics. of the difference in boxes once I get back out to workshop. Mur41
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | My apologies, I planned to do it last night but I spent last night in the emergency clinic after a fall on the ice gave me a broken nose. I'll try to get those measurements tonight for you. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The measurement across the outside of the bed roll (O.D) is about 1-7/8". I hope that helps. | | | | | Joined: Oct 2012 Posts: 7 New Guy | | New Guy Joined: Oct 2012 Posts: 7 | Thanks very much for your help. I hope you are getting over your fall. The ice and low temperatures in my area have been brutal as well. Thanks again Mur41 | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yep, I'm still young so I heal faster. I can't wait for this up and down weather to go away! | | |
