4 members (Bill Hanlon, UtahYork, LAROKE, 1 invisible), 133 guests, and 3 robots.
Topics128,087
Posts1,056,377
Members48,442
Hello all,
Anyone know how to do this and can share? Thanks in advance.
Greenman.
'61 Longbed Stepside 235
"The duty of a patriot is to protect his country from its government." - Thomas Paine
Ride height adjustment on the '60-'62 Chevy truck torsion bar front-ends, is done by adjusting the nut on the end of the torsion bar, at the frame cross member, up or down.
The adjustment is easier, and somewhat more likely to be done accurately if the weight of the vehicle is supported by a jack before trying to tighten the adjusting bolt. Raise the truck by the frame, letting the front wheels hang free, and tighten the adjusting bolt a couple of turns with minimum load on it, then lower the vehicle and bounce it up and down a few times to let it assume its new ride height.
Adjusting the ride height lower, is more easily done with the weight of the truck, resting on the tires, in "sprung-weight" position.
Thanks much for all the input!
mar Offline
Moderated
Moderated
lifting it up before adjusting to eliminate some tension to the bars and having no difficulties in tightening it up and loosing especially in exerting force to the head of the adjusting bolt which may ending it up round headed. i hope it helps
