1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 17 New Guy | | New Guy Joined: Sep 2010 Posts: 17 | Hello all, I have a 53 3100 with a 235. I am using the original transmission and torque tube driveshaft. I have a leak coming from the rear of the trans. I read in the Chevy manual that I am supposed to shim the coupling? Is it supposed to leak from the rear of the trans? It looks like it is coming from a seal where the spline slides in. Now, I am not sure if I need to replace this seal or should there be gear oil in the coupling? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are referring to leaks around the cover for the u-joint, the adjustment for the u-joint ball seals is described in the Shop Manual . | | |
