| | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | My truck was originally resto'd by some 'dude' in the deep south...Shade tree kinda guy..or so I've heard. I've found no end of BS in this truck and spent thousands replacing it. I know there's bondo in certain areas but I find that a magnet does not tell you all you wanna know. So..just what is the way to find it all ? Not sure I really want to, but would like to know if I can. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Its not easy of the paint job was done right. If you see cracking anywhere, or take a flashlight and look in the rear cab corner cavity, but really if the truck is straight and there is no appearance of a problem, I wouldn't worry too much.
The alternative is you can be OCD like me and just tear the truck clear down and sandblast everything. Then you are in for a minimum of 2 years of work. It reminds me of when I was much much younger and picked up an absolutely stunningly gorgeous girl in a bar. Funny how different she looked in the morning! Of course that never happened, but you get the idea! Sometimes looking too hard is a bad thing. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | They do make devices to check the body filler thickness. Never tried one though. I've heard of them as filler detectors and paint thickness testers.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The Filler Detective Decades ago, I bought a $10 magnet-gauge for this purpose. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Jeez and here I thought thats what those refrigOrator magnet biziness cards I get in the Parts orders were for  If it sticks, no filler... if it doesn't there's either filler or too much paint!!!
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Since magnets are not magnets, this is hard to do these days. Since the rare earth mineral market has been taken over by the Chinese, yesterdays magnets are not the same as todays magnets, which over time, yesterdays magnets have gotten weaker when todays magnets have gotten erroneous. In other words, its not a good indication *but better than nothing* of bondo depth.
Its common practice on body parts to skim about an 1/8th inch of filler on the part, then sand to smooth perfection. I think the moral of the story is not to gauge the quality of your truck by the amount of bondo, but the smoothness of the work.
The reason as I have found many times over is that fenders, hoods, cabs, etc from the 1950's have lots of very very Unnoticeable hail, rock, USE damage over them that you simply cant see but when you skim coat the entire surface, then sand properly, you wont even believe how necessary the skim coat is.
Bondo is your friend if used properly.
| | | | | Joined: Feb 2004 Posts: 29,813 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,813 | I seem to remember growing up around a bunch of body men who knew how to use a hammer, a dolly, a vixen file, and a tiny bit of lead, and they produced perfectly metal-finished surfaces without cheating with body filler. High-build primers didn't exist, and thick baked enamel paint was only used by cut-rate body shops. Lacquer paint just didn't tolerate anything but a perfectly smooth surface. Jerry
| | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | There can be telltale signs of body filler in a panel, but if this guy did a good job & blocked everything, you wont find it.
if you are going that far with it & redoing everything, then just strip it down to bare metal & start over, at least you'll know what you have. & then you can correct any mistakes the previous guy made. | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | I agree with CASO. I've bought and sold vehicles for years and take a little credit card magnet with me whenever I'm going to evaluate a car or truck. Does it stick, stick slightly, fall off--it seems to work every time to tell if it is just a skim job or put on with a trowel. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Yeah but its a little bit insensitive to not support the economy by not spending stupid money on high tech solutions... You better watch out!
