| | | Forums66 Topics128,087 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Getting ready to order a new harness for my 53. Stock 216 6v. Any good suggestions on what I should get to make the project easier? A couple of things I thought of are new firewall grommets, rubber seals for the gauges. I want to get everything needed so reordering won't be necessary. Thanks everyone and Happy New Year. Steve | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | The two insulators on the fenders, the headlight bucket rubber seals and wiring clips for the frame.My .02
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks, I forgot about the bucket seals. Are the wiring clips a ground? | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I sure would like to hear more ideas from some of you experienced 'Bolters. It's all new to me, and I am probably gonna find out I'm missing something important. Steve | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Steve,
I'm not sure what type of harness you are getting so some of this may not be necessary. But here is a quick list of items I would add.
1) Extra wire 2) Extra connectors 3) Extra sheathing 4) Stainless steel metal screws and star washers (for grounds) 5) Cable managers/clamps 6) Small wire ties or velcro ties 7) A good crimper and soldering tool 8) A DVOM with cue ball or alligator clips 9) A wiring diagram from the old chevy manual project web site
It also helps to have a body and arms that bend like gumby.
Good luck,
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the wiring clips on the frame are to hold the wires in place, away from exhaust and sharp edges .... anything other than the harness can be found at a local FLAPS or hardware store, no point in ordering a bunch of expensive bits from a vendor that you can get cheaper locally as needed
Bill | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Did you already order your kit? If not, look into American auto wire. Detailed instructions and diagrams, updated fuse panel. It's bumper to bumper. I used one recently on a 55 belair. Was awesome and easy to install.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you need no more than original circuits (plus signal lights), this harness is very good . | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks. What is extra sheathing and a DVOM with cue ball? Like I said , I'm a novice on electrical matters. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks Bill, good advice. Tim, that is the harness I am ordering. | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Steve,
Wire loom is the same as sheathing. It is not a necessity. A DVOM, is just an ohm meter. I think harbor freight sells them for under $10. It would be good tool to have to test circuits to assure they are wired properly. Cue ball clips are spring loaded plastic clip leads that do not expose a lot of metal like an alligator clip does. Their industry name is SMD IC clips. Sometimes, in a predominantly metal environment, you can introduce shorts into a circuit just by the equipment you chose to use. It is simply a quality of work preference... alligator clips or twisting two wires together will work just as well.
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks for explaining that. I already have a ohm meter. Is it used after every connection is made? I have not read the instruction yet. | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Steve,
That would depend on your personal preferences. You may be overthinking this effort. Just take your time, work methodically (in steps) and keep things straight in your head. You'll do OK.
While the overall task may look large, just break it down into smaller pieces (or circuits). Once you get started, you'll see it's pretty easy. The hardest part is wiring the gauge area... not because it is complex, but because it is difficult to contort your arms and body into the necessary position. Removing the gauges and wiring them below the dash helps, but there is still a lot of twisting.
I would use the ohm meter to check your work if you're not sure about a connection. It is always better to check your work as you go along rather than have one big smoke test when you are done.
One last thing. I am not familiar with the harness you have selected, but fuses will save you a lot rework and rework is always harder than the original effort.
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Very good tips. It is great that so many people have offered such good advice. I am ordering a harness from Classic Parts which was recommended by lots of folks. Steve | | |
