0 members (),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 10 New Guy | | New Guy Joined: Sep 2013 Posts: 10 | When I turn hard to the left, my left front tire rubs against frame and power steering lines. Has anyone used a steering stop to make it stop shorter? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Tom, most all our old trucks have stops built in, you might get more help being more specific, factory setup or ?? ... year? straight axle or modern front clip? wheel/tire size? etc
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What make, year, size truck?
There are no steering stops on my 54/55 2-ton 350 GMC COE (as are found on smaller trucks). I checked with Spanky about this, and I think he said he also could not find "exterior" stops as used on smaller trucks.
When I put the steering column back on (this coming Spring), I am going to see how the steering stops. Now, without the steering box/connection in place, the front axle is the steering stop.
| | | | | Joined: Sep 2013 Posts: 10 New Guy | | New Guy Joined: Sep 2013 Posts: 10 | Sorry for lack of data. 57'GMC, 347, long wheel base, step side, with Hydromatic. The steering is original power steering.The set up is original. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | pretty unique truck, keep'er going! ... if you don't have a manual, find one here, check about page 4 that has a pic of the stop screw adjustment for 100-370 trucks Bill | | |
