| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99558 02/25/2007 5:28 AM | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | Hi de ho..I took 2 spotlights off an Old 53 Chev car i had..Now i'd like to see if they work..How can i do this?..hook what wire to what?,..I know you use a 6-volt battery....things that make you go hmmmm..lol :confused: :confused: | | |
#99559 02/25/2007 7:05 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 50chev,
Although I'm not a spotlight person, my guess would be if you have two wires, one is ground and one is power.
If the wires are long enough, stick one on each battery post. It won't make any difference which wire goes where...it should illuminate if the lamp is good and the switch is ON.
Stuart | | |
#99560 02/26/2007 3:10 AM | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Should be one wire comin out of the switch housing. Polarity doesn't matter, just hook that wire to +, and run a wire to the body of the light for ground. You'll probably find there are a couple sweet spots on the spot as you rotate it due to corrosion & hardened lubricants inside the pivots, but for the most part they were fairly hard to kill. Just takes some time & work to clean em up & get them goin again. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
