| | | Forums66 Topics128,051 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | My 4t6 v-bars are broken at the first inboard screw. They have been soaking in Kroil for a few months. I have a little time after the New Year and am hoping to remove. I read many ways to remove but haven't give it a valiant attempt. I'm thinking either to cut with a Dremel/thin cutoff wheel on the window side and weld up after removal or drilling/tapping in the end and trying some sort of slide hammer. Looking for suggestions. Thanks prior
Dan | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I had to cut mine with a fine cutoff wheel like you describe. I have some photos in my photobucket. When I welded it back up I placed an aluminum backer in the inside. This limited the amount of weld on the inside to file. | | |
