1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 6 New Guy | | New Guy Joined: Dec 2013 Posts: 6 | Hi everyone,
I have a '63 3/4 ton and a '63 1 ton.
My plan is to combine both trucks and put either a 1/2 ton or 3/4 ton 4x4 frame underneath.
The information I need the most right now is which years is a frame a direct swap with no fabrication.
I know that with the '73 - 87'(I believe) the frame raises up where the cab mounts and you have to do some cutting and fabrication. I don't really want to do that much work.
My next question is, if I do have to go the fabrication route. How hard is it? Has anyone done it? Does anyone have a tutorial or steps to follow?
Another question, if I stick with 2WD, is it super difficult to switch from 8 bolt axles to 6 bolt? Perhaps from a 90s C/K?
Sorry for all the questions but I would like to gather parts during the winter when people are just looking to basically throw them away.
Thanks! | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Why do a "Frame swap"? That's a bunch of work, especially for a fella that doesn't want to do a bunch of fabrication. The frame and suspension on your '63 can simply be re-built. It's a ladder style frame, no reason not to use it. At least that's my take...  | | | | | Joined: Dec 2013 Posts: 6 New Guy | | New Guy Joined: Dec 2013 Posts: 6 | Neither of the trucks are 4x4 and from what I understand, that's the cheapest andeasiest route to go to make one. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | still easier to make a 4 x 4 out of the earlier frame and you don't have to alter a frame for the right w/base. whatever way that you do it make sure that it is legal when you are done
ron | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The 2wd & 4x4 frame rail profiles & cross members, are different and do not lend themselves well, to converting from 2wd to 4x4. A '63-'66 K10 or K20 rolling chassis, is the easiest, requiring the least amount of fabrication.
