Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, Ponchogl, truckernix), 111 guests, and 2 robots.
Topics128,277
Posts1,058,453
Members48,490
#995348 12/29/2013 2:18 PM
Im having issues with my fan belt wanting to twist and flip inside out. I suspect two things. My water pump pulley is not pushed back far enough and the belt that I used has the wrong V. My question is, what is the correct belt for the 235 and does anyone have a part number for it? I am running an alternator with a stock pulley. Thanks for the help.
Mitch
coffeeman #995352 12/29/2013 2:44 PM
Do you have the same width pulleys on the crank, water pump and alternator? Did you make your own brackets for the alternator? Are all the pulleys inline with each other?
coffeeman #995355 12/29/2013 3:25 PM
Have you tried a new belt? If a cord is broken in the belt it will keep rolling over. That's why it is important to not pry a belt on.
coffeeman #995363 12/29/2013 3:56 PM
No. That's why I'm asking for the right size belt. I used the one that was on it when I got it and judging by all the other stuff th P.O. did, I'm not 100% certain it's the right belt.
coffeeman #995367 12/29/2013 4:06 PM
I'm usinging a gates 7417
coffeeman #995391 12/29/2013 5:40 PM
Which belt is correct depends on year and conversions done.
If you take your belt to an auto store they can measure it for replacement.
My Blog
DADS50 #995404 12/29/2013 6:50 PM
Pre 68 Dave made a good point
The belt I referenced may not be correct for you
I have a 54 car 235 with a 12 volt 1wire alt
...pic...
Plenty of room for adjustment on the bracket.
