0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | Im having issues with my fan belt wanting to twist and flip inside out. I suspect two things. My water pump pulley is not pushed back far enough and the belt that I used has the wrong V. My question is, what is the correct belt for the 235 and does anyone have a part number for it? I am running an alternator with a stock pulley. Thanks for the help.
Mitch | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Do you have the same width pulleys on the crank, water pump and alternator? Did you make your own brackets for the alternator? Are all the pulleys inline with each other? | | | | | Joined: Jul 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 93 | Have you tried a new belt? If a cord is broken in the belt it will keep rolling over. That's why it is important to not pry a belt on. | | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | No. That's why I'm asking for the right size belt. I used the one that was on it when I got it and judging by all the other stuff th P.O. did, I'm not 100% certain it's the right belt. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I'm usinging a gates 7417 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Which belt is correct depends on year and conversions done. If you take your belt to an auto store they can measure it for replacement.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I'm usinging a gates 7417 Pre 68 Dave made a good point The belt I referenced may not be correct for you I have a 54 car 235 with a 12 volt 1wire alt ...pic... Plenty of room for adjustment on the bracket. | | |
