3 members (Otto Skorzeny, Woodcmiami, Steelonsteel), 52 guests, and 3 robots.
Topics128,052
Posts1,055,773
#995045 12/27/2013 6:55 PM
I have ordered a new oil line, but it is back ordered. I also don't like that it id glued in the fitting for the exit of the block going up to the head. Anyone know were a fitting could be had like the one on the left side of the block? I may just machine one out of a plug.
This is of course the only thing holding my engine going back in!
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
Ex Hall Monitor
Ex Hall Monitor
We reused the original fitting in my '38.
The epoxy on the right side had a crack in it. Also, I cut the line to remove it and it is full of gunk.
Randy Domeck
[email protected]
317-258-0039
Ex Hall Monitor
Ex Hall Monitor
We just reused the fitting. We replaced the line.
How did you epoxy or seal the line on the right side of the block? Solder it?
Randy Domeck
[email protected]
317-258-0039
I think that the nut seals the tube when it is tightened into the block.
That nut is a one-time-use item. If someone tries to use it again coolant will leak into the crankcase in most situations. There is another way to run the line- - - -IM me for instructions, it involves modifying some brass fittings.
