2 members (klhansen, Peggy M),
167
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99492 02/24/2007 2:59 AM | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | I am about to connect wires from my temp. gauge (red light and green light)to existing temp. sender. The connection on sender looks like a nail head that sticks out about 1/8" What connects the two wires to the sender? From manual wiring diagram it looks like a plastic connector but the NAPA parts store guy didnt know what I was talking about. Also, I'm curious about how one wire could indicate cold and the other hot when they are connected to the same place. Anyone familiar with the wiring set up. Thanks!!! | | |
#99493 02/24/2007 3:53 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | You got the wrong sender, the one for the cold/hot lights has 2 terminals. Brian | | |
#99494 02/24/2007 4:27 PM | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | Thanks Brian, The dark green and light green wires were cut off at the firewall with the mentioned sender in place. I also have a one terminal new sender. If I connect the dark green wire (red light)only will that be ok to just show if engine is too hot? | | |
#99495 02/24/2007 5:02 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Well, I don't really know. The sender for 64-66 w/guage will prolly not register correctly for a light, but a light WAS used on 67-72 w/o gauges-one of those might work, but there again GM changed from 30 to 90 ohm instruments in 67 on trucks. If you can't find a correct "Cold-Hot" light sender, lemme know I have an extra. Brian | | |
#99496 02/24/2007 11:09 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The one with the nail head is for a gauge. It will not work for a light. Your parts man should be able to come up with the right one if you tell him it,s for a light. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#99497 02/28/2007 4:27 AM | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | I ordered a two terminal temp sender at NAPA. Brian, thanks for the offer to send one. My dash was set up for lights and the engine for gauge senders but now I finally got it straight. Look at how much you can learn by fixing things done wrong the first time. | | |
