2 members (moparguy, 1955 1 Series), 93 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#994759 12/25/2013 10:56 PM
Z
Z Offline
I was wondering where I could find a cross member for a Tremec TKO 600 that would fit on a 1951 Chevy 3600 frame. Any ideas?
3B Offline
Hy zinkschevy, If the engine mounts are still stock, I don,t think a crossmember would be required, Merry Christmas.
Z
Z Offline
Its won't be because I'm putting in a v8.
3B Offline
Hy zinkschevy, in that case, if you could find a rear of engine crossmember from a 54 or 55 1st series and swap that into your frame, then you could use the factory V8 mounts from a 55 2nd and up V8 truck, and still not need the transmission crossmember, hope that helps.
Not for sure how 54/55 crossmember would help over what you already have.
Something like this universal kit is the route to take.
http://www.ebay.com/itm/47-59-CHEVY...ries&vxp=mtr&hash=item3cd2a6a207
You'll probably have to find the right trans mount for it though.
Here's an article about putting one in an early truck.
http://www.customclassictrucks.com/techarticles/0708cct_chevy_5_speed_transmission/viewall.html
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Z
Z Offline
I understand finding the right cross member and trans mount. The problem is I can't find one.
"The Fake Truck"
