| | | Forums66 Topics128,055 Posts1,055,785 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 25 | I have a COE 270 GMC with an up-draft zenith carburator. I need help setting/adjusting it? I can not get any gas through the carb. I can get starting fluid through the air intake, but nothing through the carb.
Any help/suggestions would be appreciated. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Sounds like you may want to get a carb kit, take your carb apart and soak it in carb cleaner. After soaking it rinse it with hot water and blow all the passages and blow it dry. You may want to get a shop manual to help you making all the settings. | | | | | Joined: Dec 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 25 | thanks Don, I have put a kit in it...it ran before installing the new kit. Now I can't seem to get any gas through carb...I can get it started with starting fluid in air intake! Any other suggestions? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Is the fuel pump getting gas to the carb? | | | | | Joined: Dec 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 25 | Yes, but have not tried to measure how much pressure?
If the vacuum brake booster is faulty (leaks) would that void the vacuum (sucking) ability of the intake manifold, thus no gas?? | | | | | Joined: Dec 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 25 | I am needing a bendix hydrovac brake booster for a 1949 chev 2-ton truck, or a rebuild kit for the faulty one. Does anyone have any idea(s) as to a supplier, where to find parts to rebuild, or a remanufactor(rebuilder) etc. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | | | |
