9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible), 125 guests, and 0 robots.
Topics128,114
Posts1,056,283
Members48,439
So since I'm swapping engines to a newer (1968) 230 in my 54, I'm in need of some help. I bought it from my buddy, and it came with a flywheel but no clutch.
I measured the flywheel, its a 6-bolt pattern, and a 13.5" diameter from edge to edge (not including the flywheel teeth). I'm sure I could go to NAPA with the flywheel and find one, but I just thought I'd ask for some tips/recommendations!
Not looking to race/heavy tow/anything like that... just a driver quality!
Probably 9.5 or 10 inch. Just ask for one for a 1968 230, just check the spline count on the input shaft on transmission and clutch.
Tommy
59 apache 1/2t
261 short stepside
You could use a 10.5 or 11. As noted check splines on input shaft(should be 10). I would recommend getting a diaphragm style pressure plate. Make sure you get the correct throw out bearing. You should get all the clutch linkage put together before you install transmission.
Riding in the Passing Lane
You will need to use the size clutch the flywheel was setup for. You could measure the size of the wear paturn on the flywheel.
Like Don says, make sure the TO brg. matches the pressure plate.
1972 Chevy c10 Cheyenne Super
