1 members (Hotrod Lincoln),
79
0
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99406 02/20/2007 10:00 PM | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | I have a 1946 2 ton with an original 235. It has the syle of coil with the distributor cap wire on the bottom and a "funky" cap on the top. How do I remove that cap and wire for a newer coil? | | |
#99407 02/20/2007 10:08 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dachshund, In a ongoing effort to be succinct, rip it all out and put a new coil in. Only three wires and two bolts. Is this too brutal! Stuart | | |
#99408 02/21/2007 3:18 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Then sell the Electrolock ignition to someone who needs it. Is the coil operational? | | |
