0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 11 New Guy | | New Guy Joined: Sep 2013 Posts: 11 | I am refreshing a 50 Suburban frame to replace the damaged one from my 51 pickup. I am wondering if I should remove the bracket on the frame and drill holes for the shackle type rear cab mount or modify the bracket as need be and use a mounting pad. Anyone gone down this road? Thanks for suggestions. John
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Hi John,what year are you talking about? http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Sep 2013 Posts: 11 New Guy | | New Guy Joined: Sep 2013 Posts: 11 | Oops! Should have added 50 frame, 51Cab | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | John, Here are some pictures I made of the 4" x 4" x 1/8" tube steel frame I built to support the cab of my '58 Apache 3100. I drilled holes in the corner of each of the top pieces of TS so I could attach the cab just like it attaches to the chassis. The 4 locking casters make it easy to move the cab around in and in and out of my limited space one-car garage. http://s1262.photobucket.com/user/Raleigh58/library/Cab%20support%20frame | | |
