3 members (dt235sd, Bucker, UtahYork), 160 guests, and 4 robots.
Topics128,196
Posts1,057,390
Members48,471
Then the speedo just takes off after that ie. showing 65 - 70 at approx. 40 mph, is there a way to fix this at my level, lube and clean? truck equipped w/ 283 sbc, 350auto, 10 bolt rear, 373's?
I'd like to know to? I went through about 3 speedometers to find one that worked correctly.....mine was on a stock setup. 235/4spd/4:10.
So how is the speedometer hooked up? Original cable and driven gear mated to the 350 auto?
1951 1 Ton Completed
Not sure. It was purchased this way. It does work well at 35 and under. Just spins way to fast for my actual speed, found a tutorial over on the H.A.M.B. for lubing the head. Not sure this is going to help me though as it spins too much. I would not be able to tell if it is an original or correct setup as I have no prior experience as to what this hook up should look like. Again it works like it should up to 35 mph.
