5 members (Gdads51, Wally / Montana, NJC, Otto Skorzeny, 1 invisible), 85 guests, and 2 robots.
Topics128,084
Posts1,056,334
Members48,442
#993459 12/18/2013 9:07 PM
I'm working on a 1948 3600, 216 with a tall AC canister oil filter.
The fitting on the block is a brass "T" where the male threads go into the block and there are two female threads for output.
My question. On the output side, the treads are the same size, but one has a much smaller passage or "hole" than the other. Does the output with the small hole go to the filter or the gauge?
Riding in the Passing Lane
Use the small hole for the gauge. It just shows pressure. There is no flow. If the line or gauge would leak it will be a small leak & won't dump all the oil at once.
1972 Chevy c10 Cheyenne Super
On my oil filter setup, there is a restriction inside, in the center pipe of about 1/16" or smaller. Somewhere in your setup, you need that restriction. The gauge will work off either feed.
1951 1 Ton Completed
I was thinking the smaller hole would be for the oil filter.
