5 members (Dennys28, Steelonsteel, Opelika Tom, Guitplayer, Ponchogl), 120 guests, and 0 robots.
Topics128,134
Posts1,056,401
Members48,441
I'm considering offering an LED taillight kit for Chevy and GMC trucks. This would be a retrofit kit that has a small circuit board that fits in the taillight housing behind the lens. It would be custom shaped specifically for the housing, be compatible with both 6 and 12 volt systems, positive or negative ground, and have a white led in the back for the license plate. It would also have a conformal coat for moisture resistance. If anyone is interested, please private message me so I can get a count of how many people want them. It depends on the quantity ordered, but I should be able to offer kits for $25 or less.
Paint & Body Shop moderator
I had not seen those before. Are they compatible with 6V?
Ex Hall Monitor
Ex Hall Monitor
How do you set up the brake light with the pods?
DOES THE ORIGIONAL FLASHER STILL WORK WITH THE
LOW AMP LED LIGHT OR DO YOU HAVE TO GET A
SPECIAL FLASHER THAT WILL WORK UNDER A LOW
AMP LOAD?
So you are saying these leds will sit behind the original lens ?
Is it $25.00 for a pair or each ?
What years are they going to fit ? 47-53 ?
I might be interested,after a little more detail.
Thanks,Tim
1951 3100 Chevrolet
