| | | Forums66 Topics128,120 Posts1,056,321 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99334 02/19/2007 7:48 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I'm considering offering an LED taillight kit for Chevy and GMC trucks. This would be a retrofit kit that has a small circuit board that fits in the taillight housing behind the lens. It would be custom shaped specifically for the housing, be compatible with both 6 and 12 volt systems, positive or negative ground, and have a white led in the back for the license plate. It would also have a conformal coat for moisture resistance. If anyone is interested, please private message me so I can get a count of how many people want them. It depends on the quantity ordered, but I should be able to offer kits for $25 or less.
#99335 02/19/2007 6:55 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I had not seen those before. Are they compatible with 6V?
#99336 02/19/2007 9:58 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | How do you set up the brake light with the pods?
#99337 02/25/2007 9:06 PM | Joined: Nov 2006 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 60 | DOES THE ORIGIONAL FLASHER STILL WORK WITH THE LOW AMP LED LIGHT OR DO YOU HAVE TO GET A SPECIAL FLASHER THAT WILL WORK UNDER A LOW AMP LOAD? | | |
#99338 02/25/2007 9:15 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | So you are saying these leds will sit behind the original lens ? Is it $25.00 for a pair or each ? What years are they going to fit ? 47-53 ?
I might be interested,after a little more detail.
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
