| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99330 02/19/2007 3:09 AM | Joined: Jan 2006 Posts: 16 Apprentice | | Apprentice Joined: Jan 2006 Posts: 16 | on my all original 51 coe im fixing to convert my points distribitor to pertronix ignitor electronic.i just found they make a 6volt kit.but they make 2 kits one negitive ground and one positve ground ...my stupid question is what do i have positve or negitive ground??????  and also has any body here ever seen a high performance 6v coil.......... | | |
#99331 02/19/2007 3:19 AM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | You just might look at your battery. If the positive post of your battery is hooked to ground then you have a positive ground and of course vice versa.
#99332 02/19/2007 3:22 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you've got a Chevy, it'll most likely be neg ground, GMC's used pos ground around 51
Bill | | |
#99333 02/20/2007 3:52 PM | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | :hammering: what beltfed said.
