| | | Forums66 Topics128,196 Posts1,057,387 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | What is the easiest way to determine which gear set is in my '48 1.5ton Loadmaster RK4400? The operators manual says it is either 6.17 or 5.43. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The above link is good yet perhaps confusing. Basically you can jack up one rear wheel, turn it a few times, count how many turns the driveshaft makes, and do some math.
In only a few words: A good and accurate way to do that is to turn the driveshaft 20 turns, let only one wheel turn and count the turns(assuming open differential/no locker). Now 10 divided by number of wheel turns is your ratio.
Your 48 1.5 ton has a normal open diferential, so that method works nicely.
To further explain why this works is because the differential gears throw in a factor of 2. So we used 20 turns and calculated with 10 because 20/2=10, so that accounts for the action of the differential when you only had one wheel turning.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I think they used something like a 6:17 to 1 ratio.
John | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | I appreciate all of the responses, looks like I am jacking up the rear end and counting rotations soon! | | |
