6 members (GRNHydra, 49nut, Wally / Montana, cmayna, Hotrod Lincoln, 1 invisible), 184 guests, and 1 robot.
Topics128,087
Posts1,055,980
Members48,430
#99295 02/17/2007 7:06 AM
as some of you may know i've had some issues with my charging system. it didn't dawn on me until i was prepping a small piece of metal to mount a back up light on my truck, that i had heard you should disconnect the battery prior to welding anything on a vehicle.
a couple of weeks ago i had spent the afternoon welding up some stress points on the box so my question is... since i didn't disconnect the battery during this operation, could or would this have had some effect on the electrical/charging system???
#99296 02/17/2007 7:59 AM
p.j.,
Not very likely at all!
Stuart
#99297 02/17/2007 2:55 PM
I believe it can effect vehicles with electronic ignition and computor controlled components, particularly computor chips. In future though it's best to disconnect the battery when welding, at least that's what it says in my welding book. Hope there's no damage.
Bob T
#99298 02/17/2007 4:31 PM
I opt to disconnect the alt and the battery.
And yes it can damage the alt.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#99299 02/17/2007 10:39 PM
thanks for the input guys.
think i'll not take any chances and just disconnect everything.
#99300 02/20/2007 4:07 AM
If welding electrod touched a wire in harness it could complete the circuite and cause damage. I always place my grounding clamp on a freshley made bare spot close to where I'm welding. Current will always take the shortest path. If that path is thru your wiring because of rust between parts, valuable electronics will be distroyed.
#99301 03/13/2007 2:27 PM
Beaver 53 makes a good point on the grounding close to the work. The other consideration is the farther you ground from the weld area the more possible bearings that can have current pass through them. It is not unusual to have bearings fail on heavy equipment from maintenance welding that is grounded poorly. They get small areas around the contact between the race and bearing where the arc tracks across them.
#99302 03/13/2007 2:36 PM
Brad Allen,
This usually happens when the ground path is through a bearing. If you weld on the frame of your stovebolt, and the ground clamp is on the frame, your wheel bearings won't be affected nor will any other component.
Stuart
#99303 03/13/2007 9:15 PM
I think you would be surprised at how many good welders have no ground clamp discipline. I have seen people ground right to wheel studs etc.Bottom line the closer to the work and the better the ground (clean off paint, grease etc) the better the weld quality and reduced chance of damage.
#99304 03/13/2007 9:29 PM
In arc welding, an arc is established from the electrode to the workpiece. To do this properly, the arc requires a smooth flow of electricity through the complete electrical circuit, with minimum resistance. If you crimp a garden hose while watering the lawn, the flow at the sprinkler head is much reduced. Beginning welders often make the mistake of attaching the work clamp (or electrical ground) to a painted panel or a rusty surface. Both of these surfaces are electrical insulators and do not allow the welding current to flow properly. The resulting welding arc will be difficult to establish and not very stable. Other telltale signs of an improper electrical connection are a work clamp that is hot to the touch or cables that generate heat. Another key point to consider when attaching the welding ground is to place the welding ground on the piece being welded. Welding current will seek the path of least resistance so if care is not taken to place the welding ground close to the arc, the welding current may find a path unknown to the operator and destroy components unintended to be in the welding circuit.
#99305 03/15/2007 7:44 PM
Great advice and might I say.... spoken either by a "shop teacher" or a long time professional welder.
\'48 chev 2-ton boom truck (Boomer)
'49 Chev 2-ton flat bed
'65 Chev 35ft school bus
'88 GMC 6500
'72 Superior 26ft class "A" coach
'50 Farmall "M"
'71 MGB GT
'68 Austin-Healey Sprite
'65 Austin-Healey Sprite
and various other odd British cars
and lots of old radios.....
Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
#99306 03/15/2007 8:36 PM
Or maybe someone with a "how to weld" book! smile
Stuart
#99307 03/16/2007 3:11 PM
Journeyman Boilermaker Local 182. Made my living for several years as a tube welder on most of the oil refineries, coal fired, and nuclear power plants in 9 western states. Got tired of the grind so earned a degree in Industrial Technology and a Masters in Communications.
#99308 03/20/2007 1:08 PM
And with all that stuff running around in your brain, now you can't tell your left foot from your right,LOL
