| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 13 New Guy | | New Guy Joined: Oct 2013 Posts: 13 | New to the forum and my Stovebolt. Just starting to get the basics done on my titled 50' but more likely a 53? I went to grease her up when I got to the universals I saw grease fittings and grease. The shop manual says don't use chassis grease on these fittings as they are lubrcated from the transmission. If so then why the grease fittings? They were tight to get the gun on but my NAPA gun went on without a real problem. I greased them since they had been obviously grease prior. So the real question is what is the proper thing to do? Do I need to drop them out and clean? Great forum I've been reading for the past few months, you can rest assured I'll be on here as the project progresses.
Thanks a ton from cold snowy NY | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Sounds like an open drive-line which, if the u-joints have grease nipples, needs grease. | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Someone has done some serious parts swapping. The original final drive would have had an enclosed driveshaft with only one universal right behind the transmission, so if you can see universal joints, the trans, driveline, and rear end has been changed out for something newer. Jerry
| | | | | Joined: Oct 2013 Posts: 13 New Guy | | New Guy Joined: Oct 2013 Posts: 13 | Thanks Hotrod!
Doesn't surprise me after all these years---- but it does explain why the gearbox and rear end #s don't match anything in the Chevy manuals. I have a 3 speed gearbox with serial # CBJ105999 and a rear end stamped HOA0225. That ring any bells to anyone? Gearbox has a GM 48 large casting #
Any help would be much appreciated.
Thanks guys | | |
