1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99276 02/14/2007 3:54 AM | Joined: Apr 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 99 | Does anyone know what type of grease that should be used in the shift linkage box that is mounted near the bottom of the steering column. This is the box that controls the movement of linkages going to the transmission.
Thanks in advance.
Bob | | |
#99277 02/14/2007 5:06 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Bob - originally it was white grease there, but anything that isn't too thick and can take a bit of heat works ... use lots, but don't pack it full .... and this question woulda been better in the dirveline or general forums, nothing electric involved Bill | | |
#99278 02/14/2007 4:16 PM | Joined: Apr 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 99 | Bill: The grease I took out of the linkage box was what I would call very thick. Most was black but some in the corners was a rosy/burgandy color. I would assume that the later being in the corners was original. I would say the grease is about the consistancy of butter in a cool room, just spreadable but not runny. The linkage box is cast aluminum, shaft and internals are steel.
Bob | | |
#99279 02/14/2007 4:53 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The original grease gets hard & waxy after 50 years. A good lithium chassis or wheel brg. grease will work. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
