0 members (), 79 guests, and 4 robots.
Topics128,021
Posts1,055,373
Members48,420
#992733 12/15/2013 5:28 PM
lar
Offline
Picked up steering column from 77 Camaro to put in my 40 truck . Looking for someo0ne who has done this for install advice?
Larry M
lar #993887 12/21/2013 12:22 AM
Lar hard to give much advice on installing column without knowing more detail . I put 83 el camino column in my 49 suburban without much difficulty. two issues are build a mount for column at bottom of guage area. Most GM columns have a built in "saddle" that you can fabricate around to secure to bottom of dash sheet metal. Biggest issue is determining how to connect to the steering box. Depending on length to column Borgeson shafts and couplings are your best friend. their site and tech dept can solve any alignment issues. Post some pictures and can give better info.
Good luck.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
