2 members (Guitplayer, 1 invisible),
174
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 1 Moderated | | Moderated Joined: Aug 2013 Posts: 1 | I am new to this forum, I have a 50 gmc 1 1/2 ton truck with a good body on just setting around, and was pondering if it could be put on a 77 chevy 3/4 ton, 350 engine 4x4 frame. I have found a good mechanically sound 77 3/4 ton, but the body is rusted out. Was wondering if anyone has ever done any thing like this. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | 50 frame dimensions Since no seems to have info maybe this will help you figure it out.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Yes, I might have done something similar. Your big bolt fenders will fit better than my stuff. I cut a portion of the original truck frame and welded it on top of the 73 4x4 frame which provided all the cab mount, running board mounts and about a 7" lift but lowered the center of gravity. There are lots of pictures on photobucket, see my signature lines. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | It can definitely be done. Frame swaps are for those with some fabrication skills. Since that was your first post here I don't know what level of experience you have.
I wouldn't do as Vern did (above), I just don't like stacking frames. I would rather fab my own body and bed mounts, but that's my preference.
The reason this isn't a highly popular swap is that a lot of guys don't want to go 4WD and the wider track of the full size, but if you're wanting something 4WD with a higher stance, this is your best bet.
