5 members (Gdads51, Rich'sToys, jasrking, TooMany2count, FishinToms53), 119 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
#992626 12/15/2013 3:43 AM
Hello....anyone have experience with 4x4 usage? I have a 64 k10. I'm expecting ill need the 4 wheel drive with all the snow we received. What is the protocol when driving in 4 wheel drive? If I'm running errands and the roads are bad, can I drive the truck in 4x4? is there a speed limit that I should not exceed while in 4 wheel drive? Any rules of the road would be appreciated. Everything is original on my truck and in working order so I'm concerned that I can damage the mechanics if I drive it more than to get out of my driveway. Thank John
1964 K10 Fleetside Pickup Truck
Generally speaking, you only will want to engage the 4 wheel drive if the conditions are slippery enough to warrant it. If the roads are plowed and fairly dry, leave it in 2wd. Otherwise, you can damage the transfer case. However, you can go ahead and leave the hubs locked, that will not hurt anything. That way, should you need to engage the 4wd, you will only need to lock the transfer case itself. You may need to back out of the throttle bit if you have to shift from 2wd to 4wd on the fly. Driving it in 4wd on snow covered roads will not be an issue. As far as speed, in high range, there really isn't a limit, other than what would be a safe speed for conditions. In low range, you would want to watch the speed as you could over rev the engine. Unless you're moving a heavy load or perhaps pulling a stick vehicle out, you won't need to use low range.
Bill Burmeister
Really appreciate this direction.
