2 members (cmayna, walterhvogel), 43 guests, and 4 robots.
Topics128,012
Posts1,055,320
Members48,419
#99263 02/16/2007 3:40 AM
Sometimes when I turn the ignition key I hear a whooing sound instead of the engine turning over. It lasts about a second or two losing volume until stopped -- this could happen 4 or 5 times in a row. It sounds like a starting motor/solinoid problem but other times it fires up with the first turn of key.
How can I check to find cause of problem?
Thanks!
#99264 02/16/2007 3:53 AM
redtruck65MA,
Your diagnosis is probably correct. If you value your time, a new or rebuilt starter would be the best plan. Dinking around with a problem starter, or trying to fix it a piece at a time is a real drag. Replace it and be done with it.
Stuart
#99265 02/16/2007 4:23 AM
I did that with my starter got it rebuilt works like brand new... Why get stuck somewhere.. get new cables too..Peter.
#99266 02/16/2007 4:06 PM
Riding in the Passing Lane
You need a new drive on the end of the starter. If you like to fix things yourself you can o-haul it yourself. They aren,t that hard to do. If not buy a rebuilt starter-seleniod .
1972 Chevy c10 Cheyenne Super
#99267 02/17/2007 5:07 AM
Thanks guys
Sounds like the starter/solinoid are on their way out. Time to replace them. Later when I have nothing better to do (when will that be?) I'll take the old one apart just to get familiar with what it's made up of and maybe rebuild it. It can go on the spare parts shelf either repaired or waiting to be.
#99268 02/20/2007 4:13 AM
Could be the starter drive it self. Solonoid can still engage but drive not locking. My thought.
