| | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99263 02/16/2007 3:40 AM | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | Sometimes when I turn the ignition key I hear a whooing sound instead of the engine turning over. It lasts about a second or two losing volume until stopped -- this could happen 4 or 5 times in a row. It sounds like a starting motor/solinoid problem but other times it fires up with the first turn of key. How can I check to find cause of problem? Thanks! | | |
#99264 02/16/2007 3:53 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | redtruck65MA,
Your diagnosis is probably correct. If you value your time, a new or rebuilt starter would be the best plan. Dinking around with a problem starter, or trying to fix it a piece at a time is a real drag. Replace it and be done with it.
Stuart | | |
#99265 02/16/2007 4:23 AM | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I did that with my starter got it rebuilt works like brand new... Why get stuck somewhere.. get new cables too..Peter. | | |
#99266 02/16/2007 4:06 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need a new drive on the end of the starter. If you like to fix things yourself you can o-haul it yourself. They aren,t that hard to do. If not buy a rebuilt starter-seleniod . They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#99267 02/17/2007 5:07 AM | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | Thanks guys Sounds like the starter/solinoid are on their way out. Time to replace them. Later when I have nothing better to do (when will that be?) I'll take the old one apart just to get familiar with what it's made up of and maybe rebuild it. It can go on the spare parts shelf either repaired or waiting to be. | | |
#99268 02/20/2007 4:13 AM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Could be the starter drive it self. Solonoid can still engage but drive not locking. My thought. | | |
