0 members (),
91
Mod | | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99247 02/13/2007 5:07 AM | Joined: Feb 2007 Posts: 9 New Guy | | New Guy Joined: Feb 2007 Posts: 9 | I HAVE INSTALLED A 76 BLAZER GAS TANK IN MY 57 CHEVY STEPSIDE AND NEED TO KNOW IF THERE IS A WAY TO ADAPT MY EXISTING GAGE (30 OHM) WITH THE 76 SENDER(90 OHM)BY ADDING A RESISTOR OR ???. ANY HELP WILL BE APPRECIATED AS I WOULD LIKE TO KEEP THE EXISTING GAGES. | | |
#99248 02/13/2007 5:19 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Hey, welcome to the 'bolt!! Interesting question. I don't see how that could be done but what about adapting a 30 ohm sender to the new tank? | | |
#99249 02/13/2007 5:28 AM | Joined: Jan 2007 Posts: 202 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 202 | I would try the resistor. A 1/8th watt or a 1/4 watt should. The bands would be blue, black, brown. The 4th band is not too important thought a gold fourth band is 5% tolerance. Radio Shack sells some with 1% tolerance which is best. Other wise an aftermarket may work instead of the stock one. H. Started fixing cars and such over 40 years ago and I'm also an electronic tech. I hope this helps you out. | | |
#99250 02/13/2007 5:34 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Henry; Please refresh my ol' memory here. Is that a 200 ohm resistor or (?), and where would he put it in the circuit? | | |
#99251 02/13/2007 5:46 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 600 ohm! Will this setup work when the circuit it is installed in is varying in resistance itself?
Stuart | | |
#99252 02/13/2007 7:27 PM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Well, we're talking fuel guages here not temp. guages but I'm still wondering how this would work (using a 600 ohm resistor somewhere to compensate the difference between a 90 ohm sender and the original 30 ohm sender) I'd love for someone to explain this to me. Not trying to be a smarta$$ here, just want to learn. | | |
#99253 02/13/2007 8:32 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Me too....I'll be hiding in the corner! Stuart | | |
#99254 02/15/2007 3:58 AM | Joined: Feb 2007 Posts: 9 New Guy | | New Guy Joined: Feb 2007 Posts: 9 | GREAT THANKS GUYS!
IF ANYONE ELSE HAS AN IDEA I'M STILL OPEN.
I'LL DO THE TRIAL AND ERROR SYSTEM AS SOON AS THE SNOW MELTS AND I CAN GET TO MY OLD GAS TANK AND SENDER. RICH 57 | | |
#99255 02/17/2007 2:38 AM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I don't visit this section of the forum very often but with little to do, I took a peek. I noticed some guys having a problem with this little formula question. For "Rich57" there is some good news and bad news... The GOOD... R1 x R2 90 x 45 4050 Rt= over Rt= over Rt=over Rt=30ohms R1 + R2 90 + 45 135
so:Rt is the valve you need the sensor to be. :R1 is the value the sensor is now. :R2 is the value (45 ohm)you need to put in PARALLEL with the sensor.
The BAD... "Waldo53" is right, A new sensor is the right way to go if you want it to read correctly all the time. Your gauge linearity is out the window. It will only be correct for two readings, empty and full. For an example...1/2 a tank would be 45 ohms on your 90 ohm sensor. If you plug that number in above you get 22.5 ohms or about 1/3 tank showing. A couple of other things...45 ohms is not a standard resistor but 47 ohms is and that will be ok. On temp. sensors the game is a little different in my option. The only linear portion of the temp. curve I worry about is 180 to 220 degrees. So you can "pad" an electric sensor to be linear in this portion of it temp. curve. I don't worry if the water temp. is a 125 degrees and the gauge is showing 140. I only worry about the range noted above. Hope this helps.
The UGLY...
#99256 02/18/2007 3:05 AM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | The forumla in my other post didn't get through. I guess this forum doesn't support that sort of thing so here it is again in a different way. Rt= R1 x R2 divided by R1 + R2. The valves for the different R's are in my other post. Sorry for the possible confusion
#99257 02/18/2007 8:34 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Or you can use the reciprocal of the sums of the reciprocals of all resistance values in the parallel circuit. | | |
#99258 02/18/2007 3:43 PM | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | I'm going to be like Atomarc listening to others(hiding in the corner) hoping to learn something.
My first problem is I don't understand electronics lingo, so I hope there is a layman's explanation for me.
Like RICH 57, my gauage and sender are different. Only in reverse. I'm told Old sender is 30 ohm and Brand New gauge is 90 ohm.
Just wanted you guys to know your knowledge is important to other "listeners". | | |
#99259 02/18/2007 3:43 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | "Baldy" is correct also, the reciprocal method is also a way to solve for Rt. I find the above method easier than the reciprocal method when soloving for just two rersistors in parallel But the problem is, we were not solving for Rt. We are solving for Rx. I left that out thinking solving for an unknown (Rx) with algerba for guys who don't use it everyday would be trying. Maybe I should have pointed them in the direction of a "parallel resistance nomograph".
#99260 02/18/2007 4:32 PM | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Thanx for the info. I installed new Dolphin gauges in my truck, but the fuel gauge didn't work. Finally changed the sending unit out with the one that came with the gauges and it worked fine. Now I know why!
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#99261 02/18/2007 6:07 PM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | beltfed; That's the way I saw it too. The guage would only be accurate at empty or full, anything in between would be way off. I still think the best solution is adapting a 30 ohm sender to the new tank. Good thread! | | |
#99262 02/20/2007 6:10 AM | Joined: Feb 2007 Posts: 9 New Guy | | New Guy Joined: Feb 2007 Posts: 9 | THANKS A BUNCH GUYS, I'M DISAPOINTED BUT AT LEAST I WON'T SPEND DAYS TRYING TO FIGURE OUT WHY THE GAGE DOESN'T READ RIGHT.
RICH 57 | | |
